tires
   / tires #1
somerandomguy
ford 1720
I have a 1720 ford with a loader. My back land is soft and i was thinking of adding a second set if tires to the front to aid in flotation. I致e gotten stuck several times and it always the front sinking in the muck. any suggestions or concerns.
   / tires #2
I had similar problems with my MT180 and mainly due to a damaged rim (from CaCl) I needed to change rims.
Originals were very $$ so I hunted for alternatives.
Being 4WD I needed to respect outer diameter and ended up using rear tires/rims from some brand of garden tractor.
I lucked out getting correct center configuration and wider footprint so I no longer sink the fronts. Steering is however a little 'heavier' but the result is worth it.
If you do make for a change, respect the outer diameter or you risk front end damage.
Good luck!
Doubling would, I think add much stress and steering I suspect, close to impossible.
   / tires
Thanks for the reply. I think you are right wider tire not a second one. My rims are ok but I do not know if a wider tire could be mounted to them. How mutch do you think I need
   / tires #4
My sustitutes were about 50% wider, differance was night and day.
I actually can drive on compacted snow and not sink in which allows me to push into ditches and holes.
Downside is the subs are only 2 ply but (knock wood) never a flat in the 5 years of operating. While they were tubless I did use tubes due to slow leak issues and I would guess that added maybe another ply equivilant.
Most rims have a range of widths they can accomodate and I'd guess 50% more than what you now have installed.
I will shortly need to replace as they wear much faster than rears, in other words I have gone the life span of the fronts without a flat. Also my arm muscles are better developped due to my armstrong steering. LOL!
   / tires
.Do you have power steering. I have a suicide knob on mine right now it spins easy. It is a concern though. thanks.
2025 12V Diesel Pump, Hose And Nozzle (A50323)
2025 12V Diesel...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
2014 Chrysler Town and Country Van (A50324)
2014 Chrysler Town...
2018 Nissan Sentra Passenger Car (A51694)
2018 Nissan Sentra...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
