Tires Tires going flat on 4510 w/ 460 loader
   / Tires going flat on 4510 w/ 460 loader #1
robison
Western Massachusetts
John Deere 4510 / John Deere GT235 / DR mower
I have a one-year-old 4510 with a loader and brush cutter installed. The tractor came with the r4 industrial tires, which I have inflated to about 40psi.
The problem I am having is front tires going flat. I have had two flats when clearing brush in 50 hours of use, one left front and one right front.
Is there a weakness in these tires? Are they too small, too flimsy, or what?
I used a Massey Ferguson 135 for years with an occasional flat cutting heavier brush than this. But this tractor has a loader and also I think the front wheels steer more sharply to the side, both of which could load the front tires more.
   / Tires going flat on 4510 w/ 460 loader #2
How is the air getting out of the tires?
Must be a leak, and I would suspect thorns. Is it a slow leak?
Usually tires losing air isn't a mystery, but sometimes real hard to find the point they are leaking.
I doubt it has anything to do with it being a 4510 w/ 460 loader. /forums/images/graemlins/wink.gif
It has tubeless tires and you look down one moment and they are ok, then a little later the tire is just loose on the rim. You really can't see the front tires from the cab in operation unless you lean forward and look so I don't see what causes it.
I take them to the tire place and they reseat them. No holes, no visible damage.
Not a gradual leak. They are getting peeled loose by turning and pushing or the bead is getting broken by a stick - something sudden like that.
The point is that my older tractor did not do this under similar conditions. Why?
   / Tires going flat on 4510 w/ 460 loader #4
I can't imagine the tires are going from 40 psi to being peeled off the rim in one motion. That would be in the 'catastrophic' category of a 'loud bang'. Also, would see some pretty definite scuff marks at the bead if a stick is pushing in there, or if a stump or rock was hit when turning.
I suspect they are losing air (likely a slow leak), and then come loose from the rim at low air pressure.
I didn't think a cab would keep you from seeing the front wheels. But I don't have one, so can't say for sure. /forums/images/graemlins/wink.gif
Hope you find the cause and/or figure out how to avoid it.
   / Tires going flat on 4510 w/ 460 loader #5
Sometimes you just get a bad tire! My reccomendation would be go to an auto store like napa or an orschelns and get a gallon of tire sealant like slime only the cheaper kind and put a gallon in each tire. Or take them off and get them foam filled you will never have another tire go flat.
   / Tires going flat on 4510 w/ 460 loader #6
I had my 4310 front tires filled with foam. It added about 80 pounds to each tire and they will never go flat again. Cost was about $90 per tire. You might want to check out the pictures I posted in the general owning / operating list.
I've only used them for 3 days, but am really happy so far.
BTW - I was doing a lot of brush clearing and had problems very similar to what you describe. Those thorns are murder on tires.
Good luck
   / Tires going flat on 4510 w/ 460 loader #8
Not sure of the exact brand since I didn't have a choice. It looks like soild black rubber when it sets up.
Olderog Tire in Davenport is the only one in the area that does it and I was very pleased with their service and work.
   / Tires going flat on 4510 w/ 460 loader #9
I got mine done at brahler truckers supply in St. Louis
   / Tires going flat on 4510 w/ 460 loader #10
</font><font color="blue" class="small">( I have a one-year-old 4510 with a loader and brush cutter installed. The tractor came with the r4 industrial tires, which I have inflated to about 40psi.
The problem I am having is front tires going flat.)</font>
Hey I just posted on this same subject, then found your post. I guess I should search before I post.
Robison, did you solve your flat tire issues with your 4510? I have the same setup (4510 w/460 and w/R4 tires). I have also been doing a lot of bushhoggin'.
Let me know if you found something.
Thanks,
Bryan
2005 Ford F150 XL Triton (A50120)
2005 Ford F150 XL...
2023 Kubota L2501D 25HP 4WD Front Loader Utility Tractor (A50322)
2023 Kubota L2501D...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
Toro Workman HDX-D Utility Cart (A50322)
Toro Workman HDX-D...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
