tires front 1300d
   / tires front 1300d #1
tock
yanmar ym1300d
Hi there no one of you who has to change his front wheels tractor 1300D 155d or 4x12 for kubota rim 5x12 to 6x12 power meter of tires instead of 5x12
Obviously always keeping the same ratio silk 23 inch tall tire height as I would like to ca because I have a front shovel and tire 5x12 in the front is the hard life thank you
Excuse the English I speak only French (Quebec Canada)
tock
   / tires front 1300d #2
I don't understand the question. Anyone make it a little plainer for an old man? :confused3:
   / tires front 1300d #5
I think you are asking is it OK to change from your 5 x 12 front tires to 6 x 12 on your Ym1300D. I would not do it, but would order 5x12 tires from Hoye in Texas or elsewhere. Having said that, it might be ok as long as you only use 4wd in soft terrain.
   / tires front 1300d
The reason why i want to know if kubota rims could be put up on a ym1300d is that i stay
In quebec,canada and if i order parts in usa i have to pay shipping and customs and it’s
Expensive for example :2 tires on abay at 134$ will cost to me 134$ plus 100$shipping and 40$ customs fer a total of 274$ in canada i can buy 6x12 but not 5x12 then if i put up 6x12 instead of 5x12 (keeping the seme 23 inches diametre) i want to be sure that i will not broke my tractor.
If nabody knaws the answer , i will no take chance and order with hoye 2 tires 5.12 to replace my actual 5.00x12 and also a rim because i have one broken
Thamks fer your help,whatever your answer
tock
   / tires front 1300d #8
I don't see the problem. all you have to do is compare bolt patterns, (center-center, opposing holes), and center holes. I'm sure a phone call would suffice
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
