tires for john deere 4410
   / tires for john deere 4410 #1
harjen
St Peter, Minnesota
John Deere 4410
I am getting new tires for my 4410. I have turf on now and want to go to something with a more agressive tread either ag or industrial. The book calls for 7-14 and 11.2-24. if I put a 27x8.50-15 on the front, what size do I need in the back. What are my other size options.
   / tires for john deere 4410 #2
First question everyone is going to ask is if the 4410 is four wheel drive. If not, the tire sizes can be altered with very little ill effects, within reason. If four wheel drive, then the rolling ration between the front and rears has to be maintained.
David from jax
   / tires for john deere 4410 #4
Here is the tire size listing from JD on your 4410...Bar or R1-11.2-24rear 7-14front. Turf or R3 - 41x14.0-20rear 27x8.5-15front. Industrial or R4- 15-19.5rear 25x8.5-14front.
   / tires for john deere 4410 #5
What condition are the turf tires in? I am looking for a real good used set for my 4310... I have R4's on it now and need turfs once in a while. :)
Darin
   / tires for john deere 4410 #6
Looks like what ever you decide you will need new wheels. I'll bet used wheels for R4s will be the easiest to find. You may find a dealer that changed a machine to something different at the point of sale and has a set to sell.
   / tires for john deere 4410 #7
If it were me, I would first decide which tread pattern I wanted and then purchase the size that would have come on the machine from the factory. As someone else mentioned, looks like new tires and wheels will be required. Will be an expensive proposition. Might be worth considering selling the turfs to offset the cost or hold onto them a little while to see if you wished you still had them.
INOP/NON-RUNNING 2000 Ford F-450 Pickup Truck, VIN # 1FDXF46S9YED80883 (A44391)
INOP/NON-RUNNING...
2020 CAT 239D3 Skid Steer (A44391)
2020 CAT 239D3...
Pallet Forks (A44501)
2018 BOBCAT S570 (A45046)
2018 BOBCAT S570...
2014 LOAD TRAIL GOOSENECK TRAILER (A45046)
2014 LOAD TRAIL...
24in Tractor Backhoe Bucket BT4555 (A44789)
24in Tractor...
