Firefly0556
- Joined
- May 4, 2020
- Messages
- 5
- Tractor
- JD 790
Gentleman, I need some help. I have a JD 790 2WD with turf tires front 23x8.50-14 / rear 13.6-16. I want to get some new rear tires that are more aggressive. In fact I should have never got the turf tire option to begin with but they have worked out so/so. I just have to becareful not to get in mud. They are pretty much dry rotted now and I need 2 new ones. The fronts seem to be ok. But the rears are bridge stone and the fronts are goodyear. Yeap came from the dealer new like that.
I was in JD today and of course I left pissed at their prices. Not even going to get into what they wanted to change out 2 tires and refill them. I did find out that I can go with a 12.4x16 tire. What I forgot to ask was and I assume it is a different rim for a r4 tire size of 15x19.5. Does anyone know if they use the same rim as the turf tires 13.6x16 are is it different. From what I can find online it looks like they use the same rim. I got pissed at the prices and forgot half of the stuff I needed to ask.
I have found 2 sizes in a tire Id like to try the goodyear R14. The sizes are 15x19.5 which JD says is the true r4 size for the 790 if I dont require a new rim size. The next close one is 12x16.5. Do you think the 12x16.5 will work? I did find a fire stone ag tire in 12.4x16 that will work. BUt that new r14 looks nice.
I do not want to buy new rims.
Thanks for any help.
