jcummins
Veteran Member
- Joined
- Jan 14, 2007
- Messages
- 1,637
- Location
- Creal Springs, IL
- Tractor
- Kubota M7040, F3680, Mule Pro Fxt
I've mowed with this F3680 for two years...have gotten it stuck a few times, but this last mowing, got it stuck twice. One area, I had gone thru a couple of times but it finally caught me. I probably should have not gone thru, but the other caught me completely off guard. I was coming up from the bottom of a pond dam and there was just enough wetness...which you really couldn't see...that made the turf tires lose grip, The machine is far more capable, but these tires are not.
I looked before for tires in the 24x12x12 size, and choices are limited, but now I'm seeing a few more options. For example this one... Amazon.com: TWO 24X12. -12 24x12-12 OTR Lawn Trac Bar Lug Tires 4 ply Rated Heavy Duty: Automotive
Another option, I have a Mule Pro, which I will eventually change tires on, and the rear tire on it now is a 26x11x12. I'd REALLY like to put those on the F series, but not sure what it would do with the 4wd ratio.
Has anyone switched tires on the F series? and what did you go to?
