Tires Tires for 3720
   / Tires for 3720 #1
jcmseven
Veteran Member
western NC
JD 2320; 4520
Fellow Posters:
I have been thinking about getting a set of R1 tires for my 3720 (if I decide to keep it). As you may recall, earlier this year my local dealer had a 3320 with R1 tires, and they were interested in trading out those for R4 tires. We swapped out wheels and I tried the JD 11.2x24 R1's. I noticed the traction difference when pulling a box blade, etc., but I did not like the stability on hills as much and I wanted more contact patch for loader use, i.e, the tire deformed some when using with a heavy load in front. Although this is silly, I also did not like the looks of them, as they seemed too narrow. So, after trying them two weeks I opted to go back with my R4 tires. These tires do fine, but there are times I would like to go R1. I noticed on the Galaxy tire site that they make a 14.6x24 rear tire and I am sure they also make a 15x19.5 tire in ag style tread. I have read in the owners manual from JD that "the tires are carefully selected to match the tracking and load requirements" and then some lingo that essentially states one should not get any other tire other than what is spec'd stock. My question is, can I go with an R1 pattern using my existing wheels, or does JD or another company offer a legitimate OEM replacement tire for either my current rim or the 24" rim that would work and not result in issues for the tractor??? Are there any hidden problems that could result from considering such a replacement??? Thanks in advance.
John M
   / Tires for 3720 #2
John, when I went through the process of buying new R1's and rims, I had the good fortune of a fellow TBNer "Keoke" explain the mechanics of what considerations had to be made before I took the leap and put down my money.
In a nutshell --- the excerpts of what George provided me with over the several months that I researched prior to buying a set of OEM R1's for the JD 990 tractor and using them on my JD 970 was that Deere recommended a "front to rear wheel slip rate or wheel overrun" of 1% to 5%.
The formula to calculate the "overrun" is: front tire SLR (static load ratio) X front to back gear ratio (from JD by tractor model) / (divide) rear tire SLR.
For example; the Titan tire website lists the 14.9x24 R1 rear tire as having a SLR of 22.7. The 8x16 R1 front tire has a SLR of 13.9. So, 13.9x1.691(JD 970 gear ratio)/22.7=1.035-1.00=.035x100= 3.5% slip rate. That's within the recommended range and acceptable.
Keoke also provided me with another way of calculating the slip rate using rolling circumference. However, I have read that using rolling circumference in lieu of SLR is not the recommended method for tires less than 24 inches in diameter (most CUT's).
The rolling circumference method is very similar --- RC (front tire) X gear ration / RC (rear tire) = slip rate -1.00 X 100= % slip rate.
Good luck, AKfish
   / Tires for 3720
Thanks AKfish. I will have to brush up on my math to do this, but it seems I might have some tire options here.
John M
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52748)
Kubota BX2680...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
2025 Mustang MP4800 2in Submersible Pump (A50322)
2025 Mustang...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
