Tire width of R4s
   / Tire width of R4s #1
BrokenScope
Could someone tell me the actual width of the R4s and what the width is set at the widest position fromoutside to outside.Im thinking of swapping my ags in on a set. My tractor is a L 3010 and I would like to get it wider for steep hills. Ill be using it mostly on dry ground. Thanks
   / Tire width of R4s #2
I suggest you contact Steve Carver a member here on TBN. He is usually great about getting right back to you with technical answers about Kubota's.
   / Tire width of R4s #3
There are a number of different sizes of R4's. If you have an owner's manual, it may give you the range that fit your tractor. It will also show the recommended spacing (C to C) then all you need to do is add the width of one of the tires................chim
   / Tire width of R4s #4
Check out:
<A target="_blank" HREF=http://www.goodyearag.com/tirecatalog/SGLSize.html>http://www.goodyearag.com/tirecatalog/SGLSize.html</A>
If you poke around in that area, you'll find pages for rear tires too.
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2007  BIG TEX 16' T/A TRASH TRAILER (A52472)
2007 BIG TEX 16'...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
NEW Woods 6ft Finish Mower (A53472)
NEW Woods 6ft...
