Ballast Tire swap & foam filling
   / Tire swap & foam filling #1
newangusranch
I own a Massey Ferguson 1240 four wheel drive with turf tread tires (front: 27 X 8.50-15 & rear: 355/80D-20 R3). I would like to swap over to an ag type tread design. MF calls for changing wheels ($expensive$) in order to fit the recommended tires (front: 7-14 R1 & rear: 11.2-24 R1).
Does anyone have the recommended type tire and wheel set-up for this tractor (a version of an Iseki?)? If not, can you refer me to a source for either getting the proper wheels/tires or making a swap to my current wheels. A local dealer has suggested using an industrial type tread (27850 X 15 & 145 X 20) that would give me a more aggressive tire design without having to change wheels. I know that any changes need to be very close in order to not compromise the drive train/differential ratios.
The dealer also suggested getting the front tires foam-filled since I have been getting repeated flats due to multiple thorn punctures ($ but would save on frequent down time). Any problems with foam filling in your experience? Appreciate your time and assistance - BC
   / Tire swap & foam filling #2
Sorry, but I can't help with the wheels. But I do have a MF 1455v with industrial R4's and have been impressed with the traction and additional floatation due to the added width over ag's which is important here.
I also have a problem with locust thorns, and have been looking at "ultra-seal". Apparently they have a good product that is not corrosive, and I also don't want to add weight so that's a factor too. I believe the ultra-seal is about 70.00 or so a gallon, and it would take two or three to do all four of my tires. That's still cheaper than foam and a lot lighter if that makes a difference. Don't have a web site for it, but do a "google" search if you're interested. I do recommend the R4's.
1997 MONON 102" X 53' T/A VAN TRAILER (A51243)
1997 MONON 102" X...
UNUSED FUTURE MINI SKID STEER HOLLOW WOOD GRABBER (A51244)
UNUSED FUTURE MINI...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
