Tires Tire sizes ?
   / Tire sizes ? #1
Slackdaddy
Land of the Free
Kioti CK20HST
I want/need "larger" tires on a future CUT i will be buying.
What is throwing me is I see the same model in different pictures with differant size front tires. I have read the specs, so I know what size the tires "should" be.
Looking at the 10 series ad, the 3510 on the back has huge tires in relation to the rears, but in other pics they look like skateboard wheels.
On Tractor house.com, look at the under 40HP Mahindra ads, same models (differant ads), have (or appear to have) grossly differant size front tires ?
I know You can not just change the tire sizes do to the 4wd and axle gears, so what gives ?
Thanks,
Nick
   / Tire sizes ? #2
All of the 3510's I see on tractorhouse.com have the industrial tires on them. The difference between industrial and ag tires might be the difference you are noticing. The ag tires will be taller yet not as wide while the industrial tires will be wide yet not as tall as the ag tires.
I have also seen photos of 3510's where it was really a 4110 but they just changed the model number on the side of the hood. Maybe you've seen a photo like this that is throwing you off?
   / Tire sizes ? #3
My understanding is the 3510 and 4110 are the same tractor except for the engine. I put R1 tires for a 4110 on my 3510 (all the way around). I really like my new tires. If you want a 3510 and want the bigger tires (4110 tires-R1 or R4) get them when you order your tractor. It'll probably cost more, but I wouldn't think it would be too much, but I don't know.
http://www.tractorbynet.com/forums/mahindra/94597-3510-lift-kit.html
   / Tire sizes ? #4
I have asked the company before and they wouldn't ship a 3510 with 4110 tires. That was a few years ago so you could ask your dealer to check into it. As you know you have to change in a set of 4 to keep your lead lag ratio correct. I know it can be done. Most likely your dealer will get stuck with a set of wheels and tires or a heafty shipping bill to send them back. I have a set of 4110 ag wheels & tires on hand right now.
   / Tire sizes ?
Edit,
meant to say want larger front tires in relation to the rear (skidding logs, in hilly woods)
Nick
   / Tire sizes ? #6
Slackdaddy said:
Edit,
Nick
Nick,
That is something you can't do. The ratio between the front and rear tires has to stay the same or you will have transmission problems.
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2017 Ram 4500 Bucket Truck (A52128)
2017 Ram 4500...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
