tire size question please help!
   / tire size question please help! #1
BWS
seattle area
kubota l3830 hst/723 fel
i have a 1949 cub 2wd just got with a like new set of rear ag tires size is "9.5/9-24"??? if i order my new n.h.tc33d with r/4's can i buy some rims [front/rear] and mount these up on a set of 24"x? rims?how much do they get for rims.i know the r4 rims wont fit and i would have to buy a front set of ag tires.ps whats a rusty 1949 cub worth.might run dont know?.
   / tire size question please help! #2
I am not familiar with the TC33d. If it is 4WD then only go with front rear tire combinations that are dealer recomended. On a 4WD if you get the size ratio's wrong between the front and rear tires you will most likely damage/destroy some of the drive train components. Very expensive to repair and ont covered under warranty if you changed the tire sizes. There are several discussion threads on this board on this subject.
   / tire size question please help! #3
the 'cub' rears are way to narrow.most of the newer 4x4`s have 12 or 14x24`s.cubs useally bring $1000.00 to $3000.00 depending on condition and attachments...Sid
   / tire size question please help! #4
The Cub's rears are narrower, but I don't know about too narrow. They would certianly cut into snow or mud better. Just by sight, they are not any narrower than the R1's on my buddies B7300 Kubota.
   / tire size question please help! #5
The Cub is priceless! They are soooo cute! And, they can work pretty hard for thier size.
Check Ebay for comparative Cubs. Als, check <A target="_blank" HREF=http://www.ytmag.com>http://www.ytmag.com</A> in the classified and photo-ad section.
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Wright Sentar (A50120)
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
JOHN DEERE LOT NUMBER 138 (A53084)
JOHN DEERE LOT...
