Tractor Sizing Tire size info 8-18
   / Tire size info 8-18 #1
KenCombs
I have an MT180H with 8-16 tires fropm a mt160. Apparently these were installed by the new dealer as the rims seem to match the rest of the tractor. The original factory tire was a 9-18 ag lug tire. I need the diameter of the originals so I can determine what turf tires would be near the same size. The tires on it now are about 31-32 inchs in diameter and the turfs I am considering are 36" in dia and 12" wide. There may be enough space avialable to hande a 12w tire, if not I will make spacers, assuming the diameter is close to that of a9-18, Have been able to find just about every other size on the Goodyear and Firestone site, but no 9-18.
Can anyone help??
   / Tire size info 8-18 #2
I own a MT 180 HD, and I have the big wide turf tires on my 4-WD tractor. I'm not sure if you have 2-WD or 4-WD but my owners manual lists the following for turf tires:
Front (2WD) 20x8.00-10
Front (4WD) 6-12
Rear (2&4WD) 9.5-18
For AG tires:
Front (2WD) 4.50-10
Front (4WD) 5-12
Rear (2&4WD) 8-18
I hope that helps.
Thanks for the info. My problem is that I have 16" wheels and would like to go to turfs that are near the same Diameter as the original 18" tires . Could you measure the diameter of your turfs? I think my 8-16 ags are about 31". The 18s should be about 32.5 or 33 but I want to be sure before investing in new tires that are too big.
I was wondering about the fronts also, thanks for that info. I will be looking for some of those too.
   / Tire size info 8-18 #4
I have a IH 234 which was made by mitsubishi, but I have turf's 6-12 on the front and 9.5-18 rear I wanted to put ag tires on but I need the 8-16 rear rims to switch to ag,I wouldn't mind trying to find somebody that wants turfs that have ags to trade with.
Twinstackram, I sent you PM. I am interested.
Thanks.
Sent another PM.
   / Tire size info 8-18 #7
I am pretty sure that Bridgestone makes an 8-18 turf tire.
2015 WESTERN STAR 4900 SF (A45333)
2015 WESTERN STAR...
2015 TYTANK PNEUMATIC DRY BULK TANDEM AXLE TRAILER (A43004)
2015 TYTANK...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A43004)
2019 FREIGHTLINER...
2010 APACHE TRAILER INC. GOOSENECK TRAILER (A45046)
2010 APACHE...
2007 WILD WEST  GOOSENECK TRAILER (A45046)
2007 WILD WEST...
2015 FORD F750 BOX TRUCK (A43003)
2015 FORD F750 BOX...
