Tire sealer or tube?
   / Tire sealer or tube? #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
I run R4's on a Deere 4200 MFWD. A few weeks ago I had the RF tire go flat and break the bead seal. I took it off and to a tire dealer down the road who cleaned the bead and the rim thoroughly and got the tire to reseat (after a few tries) then checked it with soap and water for any leaks. What I'm trying to convey here is they did everything right so far as I could tell and found no leaks whatsoever.
A couple weeks ago I thought that same tire was a tad low when I had it on my trailer so I filled all of them to 35 PSI per tire specs. This afternoon I again found the RF tire down (and, again, the hard way /w3tcompact/icons/hmm.gif ). I don't think I'm breaking the bead seal just from turning sharp or anything as innocuous as that. There must be a leak somewhere.
My Kubota dealer friend suggested tubes all the way around even before I had this problem. I sure need to do something different. What's the consensus here? Tire sealer or tubes?
   / Tire sealer or tube? #2
That's a tough one. I wouldn't know what to tell you. One thing to think about, though, is that tire repairmen DO NOT like to deal with tire sealer. A lot of them won't even work on a tire that has sealer in it.
   / Tire sealer or tube? #3
Have you checked/replaced the valve stem?
Could be the likely culprit.
   / Tire sealer or tube? #4
Personally, I'd have to take that tire and wheel off the tractor, get the soapy water, and find out for sure where the leak is before I decided on a course of action. It could be the valve stem core, around the valve stem, the bead, or that you've picked up a nail, thorn, etc.
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
20 Yard Rolloff Container (A51573)
20 Yard Rolloff...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
BAUMA LIGHT TX 12 LOT NUMBER 240 (A53084)
BAUMA LIGHT TX 12...
