TIRE SEALENTS ? G-SLIME vs. OREGON
   / TIRE SEALENTS ? G-SLIME vs. OREGON #1
bullbreaker
Elite Member
SW FLA
D Ranchers daughter'$
Was trying to do a TBN search could not find much on Green Slime,Oregon tire sealent products.Maybe I was doing it wrong :confused:
Once in a while like most of us get slow leaks on small equipment(L3400 Bota-ag tires,JD gt235).Any comments pros/cons Green Slime vs Oregon or any comparable product($$$).Local lawnmower shop swears by Oregon.The fellow that owns it says Oregon stuff works better of course on holes of resonable diameters.Also he said Oregon on a long term situation would not rust your rim like G/S :confused2:
Was also looking to have one of these type products as back-up for when I pull small horse trailers, campers,etc.
Truth or snake oil ?
Thanks in advance !
Boone
   / TIRE SEALENTS ? G-SLIME vs. OREGON #2
I've just become a fan of Slime in the last couple of years. I put it in riding mower and ATV tires. I had two tires with slow leaks that are fine now after simply adding the stuff. The mention of rim rust surprise's me. I didn't know that was an issue.
Tip: I put a small zip tie on the valve stem so I can keep track of which tires have been slimed.
   / TIRE SEALENTS ? G-SLIME vs. OREGON #3
I have used green slime in tires that had slow leaks that were too hard to find.
If I change a valve stem, take the wheel off, inspect the heck out of it, put it in a water bath and STILL can't find the leak I usually conclude that it only goes down when rolling, so I have ZERO chance of finding it.
THAT is when I go for the slime jug.
I used Prestone yellow in a set of R4s before filling them with RimGuard, ran it around for a few minutes to distribute it, etc.
I have had no leaks on that tractor, though I can't say that I have seen anything poking out of a tire on it either, so maybe it works, maybe it hasn't had to (-:
   / TIRE SEALENTS ? G-SLIME vs. OREGON #4
Thanks in advance !
Boone
These products work, but degrade with use. There is fibrous material in them that aids forming a filter cake to block a hole. This material breaks up with extended use making it more and more important to park with the hole down.
larry
John Deere 2155 Tractor (A51573)
John Deere 2155...
Electric Concrete Mixer (A51573)
Electric Concrete...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
