Tire Selection Tire & Rim(s) needed 12x5 4 bolt ( 4.5 inch across holes )
   / Tire & Rim(s) needed 12x5 4 bolt ( 4.5 inch across holes ) #1
KenMT372d
Rowlett, TX
MT373D, JD_425, JD_1-Series
Looking for (2) 12x5 4 bolt rims. Also need (2) turf tires 12x5 or 12x6. All items for MT373d compact tractor. Anyone know of hub adapters to change from 4 lug rims to 5 or 6 lug rims as an options?
   / Tire & Rim(s) needed 12x5 4 bolt ( 4.5 inch across holes ) #2
Summit Racing has some 12 inch wheels that may work for ya.
Have not been able to find a vendor for new 12x5 4 bolt rims or the turf tires. Did locate 6 ply 5.30 X 12 trailer tires with tubes online at Walmart.com for less that $80 US for two tires and tubes shipped. Have them now mounted on the old rims and they will do the job.
Item Qty Total
SUPERCARGO Trailer Tire 5.30-12 6PR SU02 $29.29 2 $58.58
Hi-Run Tube 5.30/4.60-12 (TR13) for Trailer Tires $8.66 2 $17.32
   / Tire & Rim(s) needed 12x5 4 bolt ( 4.5 inch across holes ) #4
Is that 12x5 4 bolt rim the same as US Boat Trailer wheel? Lots of those around. And I vaguely remember that early Chevy Vega or something similar, used that bolt pattern for 13 inch wheels.
Wish it was the same as small boat trailer 12" rims. The tractor 4 bolt pattern is wider and has a larger center hole for the 4x4 hubs.
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52748)
1994 Thomas Built...
