Tires Tire ressure question
   / Tire ressure question #1
tillboy2001
I have a 4120 with R4 tires. When I checked the pressure on the front tires they were pretty much in line with what the book said. When I checked the rear, it didn't even barely register on the gauge. Here's what the book says for the rear tires for R4:
Rear Tire Inflation Pressures
NOTE: Minimum / Maximum pressures given. Minimum pressure is for unloaded, unballasted tractor.
17.5L-24 8PR R4 TI 138 kPa/180 kPa (20 psi/26 psi)
I went ahead and put air in them until it registered 17 lbs on the gauge. What are you guys running? I wonder why it didn't even register the first time I checked? They didn't 'look' low but they sure took a lot to get them up to only 17 lbs. I didn't even go to the low end of the recommended pressure (20).
   / Tire ressure question #2
Are those rear tires filled?
I don't think the stem type pressure gages are particularly accurate at low pressures, so if it wasn't registering, you probably had 10 to 12 PSI in the tires.
There is a lot of volume in those rear tires. Depending on the air hose pressure and CFM of your compressor, it can take a while to up the pressure. If your tires aren't filled, it'll take even longer.
I have my ancient (it was my father's actually) Sears compressor set at 120 psi. I don't know what CFM it pushes through, but probably not more then 10. Mine takes a while to fill the tires too. My tires are filled (~75%), so that reduces the volume quite a bit.
I run about 15 to 20 PSI in the rear tires. 20 PSI in the fronts, but I up that when I'm using the loader.
Rear tires are not filled. I've got 220 lbs of weights on each side. I might try a different gauge and see what it says. It did take awhile to fill to this point, as you said, because of the volume. Maybe I better get a more sensitive gauge and see it they read over the max pressure. I don't want to leave them this way for too long if I'm uncertain about the pressure that's in there right now.
2000 International 4700 Truck (RUNS) (TITLE) (A50774)
2000 International...
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
Toro Workman Utility Cart (A51694)
Toro Workman...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
