Tire Repair Options
   / Tire Repair Options #1
CanuckGT
Bronze Member
Dino Valley,Ab Canada
Kioti CK30 HST
Cleaned up a pile of garbage,house reno material,etc last fall, lots of nails ,etc.
Thought I made it without a puncture but I see my front right tire has a slow leak now.
So, never repaired a tractor tire before but do have plugs for my quad tires and was wondering if this would be a good way to fix a flat? Or do I have to remove it and take it in to a tire shop to get a patch on it?
   / Tire Repair Options #2
The best way is to have it patched. You could use your plugs but they aren't as strong of a repair but may last until the tire wears out.
   / Tire Repair Options #3
Slime it!!!:eek:
   / Tire Repair Options #4
I plug mine, and there are two in one tire and one in another...zero problems. I have also probably plugged two dozen tires and only had one that would not seal because the hole was too big even after doubling up on plugs. If your tires are filled just make sure you roll the nail to the top before the repair, or fluid will run out making a mess.
Murph have you had luck with slime? It's never worked worth a hoot for me, tried it twice, still got flats so I gave up on the stuff.
   / Tire Repair Options #5
Plugs are a temp fix, good for a few months. You can reign but I would patch.
   / Tire Repair Options #6
I've had good luck with Slime in little, thin lawn tractor tires. I think the actual punctures were made by multiple perforations from thorns so the holes were pretty small and leaks were slow. But I think a real tractor tire would require a huge amount of slime and that would only work for very small leaks in unfilled tires.
Given the difficulty of patching a tractor tire, I'd be inclined to plug it and patch it later if the plug failed. Particularly so if the tire was filled with liquid. Just my opinion.
   / Tire Repair Options #7
If it is only a nail or screw just plug it!
   / Tire Repair Options #8
I would take the tire to a tire shop and have it patched. A properly applied patch has the best chance of being trouble free. The slime may work but if it doesn't, you probably won't be very welcome at the tire shop.
All of this of course is just my opinion.
   / Tire Repair Options #9
You are going to get a zillion replys about Slime. I would take it to a tractor dealer and have it repaired.
   / Tire Repair Options #10
Realistically, plugged(if done correctly) is as good as, if not better than "patched at the tire shop".
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
