I suggest that you drop the tractor at the dealers and have them look at the front suspension. Seems that there has to be a problem beyond the tire and rim. It might be that the wheel is being pushed sideways when you are turning and that is tearing the tire from the rim. I am more inclined to believe that there is something mechanical causing this problem other than just poor quality tire. If you get the tire replace, then swap the right for the left tire and see what happens. If as in the past, the left is the one that keeps going bad, then it definitely is the tractor, not the tires.
