Feb 21, 2007 / Tire pressure #1 M MoKioti Member Joined Jan 9, 2007 Messages 37 If a tire has fluid in it do you still go by the manual and inflate to recommended PSI? The tractor was bought used so I have no idea how much liquid was added. Thanks in advance for any replies.
Feb 21, 2007 / Tire pressure #2 DieselPower Elite Member Joined Sep 30, 2006 Messages 2,756 Location Fairfield, PA Tractor JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170 Same preasure. Only real difference is you don't have the same volume of air in the tire anymore. Alot of the volume is now liquid.
Feb 21, 2007 / Tire pressure #3 N NY_kioti_sales Silver Member Joined Apr 21, 2005 Messages 127 Location Owego, NY USA Tractor DK 65 S yes, same pressure. You need to have the valve stem at 12 o'clock to check or you will lose some fluid.
