Tires Tire Pressure
   / Tire Pressure #1
cperky
Middle TN
John Deere 1025r with 120r front end loader, Hustler zero turn mower
Had a tire pressure issue today on my trailer but it got me to thinking about the tire pressure on my tractor. My question is what should the pressure be if the tire is loaded with fluid? How do you check the pressure, make sure the stem is up?
Thanks,
Chris
   / Tire Pressure #2
The pressure should be the same no matter whether the tire is filled or not.
Measure the pressure with the valve stem up unless you have one of the gauges designed for liquid filled tires. The pressure should be the same no matter where the valve stem is, but if there's the calcium chloride or glycol anti-freeze in the liquid, it could damage an ordinary gauge.
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
2008 Ford F350 Bucket Truck (A47384)
2008 Ford F350...
2016 Ford Explorer...
1600 gal Poly Tank (A50515)
1600 gal Poly Tank...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
