Tires tire pressure
   / tire pressure #1
mit
hey u all,
i am trying to find the tire pressure for the front tires for my mitsubishi d 1850 fd tractor.i checked it and it has 15 psi.ipumped it up to 20 psi i cannot find the markings on the tires the walls are old and a little cracked.at 15 psi the tires looks soft (bulges at the bottom).any help would be appreciated.
   / tire pressure #2
Is it 4wd, or 2wd, and does it have a fel on it. On a 2wd tractor, 30 lbs will make it steer better on hard surfaces, but you will get better steering in soft, just tilled earth with about 20 lbs in it. On 4wd tractors, you want about 20 lbs for soft conditions , too, but if you go too soft, the tires can slip on the rim. Loader tractors need higher pressures to keep them on the rim with increased loads. Hope this helps somewhat.:D
   / tire pressure
its a 4wd with a loader.
   / tire pressure
this from the book guys.front ag tires 37psi. or 2.6kg/cm/sq
rear ag tires 17.1 psi or 1.2kg/cm/sq
front es tires 31.3 psi or 2.2kg/cm/sq
SHOP CART W/ FRONT & REAR HITCH'S (A51248)
SHOP CART W/ FRONT...
72in Dual Cylinder Grapple Skid Steer Attachment (A51691)
72in Dual Cylinder...
2021 Krone ECTC 400 (A50123)
2021 Krone ECTC...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
CFG Industrial SAII100 (A50123)
CFG Industrial...
