Tire Pressure With a FEL
   / Tire Pressure With a FEL #1
jones2127
SW Missouri
Mahindra 4025
I have a Mahindra 4025 with FEL. The recommended front tire pressure is 20 psi in the field, but I don't think that is considering the FEL. At 20 psi and a full load of dirt in the bucket the tires look way under inflated. The tires max psi is 50lbs according to the sidewall. My question is this, how much can I safely increase the tire pressure to compensate for a full FEL?
   / Tire Pressure With a FEL #2
My tractor OM gave a low and high number for the specific tires on the tractor. The OM for the loader says to use the high number plus 4psi. Just a suggestion because it works for me.
   / Tire Pressure With a FEL #3
I keep mine at 35 or 40 all the time as my FEL is always on.
   / Tire Pressure With a FEL #4
Definitely add pressure (35 PSI minimum and see how that works) when using the loader.
Low pressure and you can run those tires right off the rims. I almost did that when I first starting using my loader. Don't make my (near) mistake.
   / Tire Pressure With a FEL #5
My JD 4500 has 10.00-16.5 R4s on the front. Manual specs 12 psi without loader and 16 with the 460 loader. (For reference in comparing, the 4500 is a 39hp compact tractor, bucket is 72".)
I am guessing you would add at least 4 psi for your loader, but am surprised your manual does not show anything about tire pressures with loader. (I have a manual on tractor and separate one for loader, base inflation info is in tractor manaual, the extra 4 psi is shown in loader manual.)
I would think you can safely run right up to max press shown on sidewalls.
   / Tire Pressure With a FEL #6
My manual specifies PSI with and without FEL. I have seen tire damage from over filling and of course rolling one off by under filling. I find the smaller units to be less sensitive to this.
   / Tire Pressure With a FEL #7
If I remember correctly, my Kubota L3940 states that I should run the front tires at their max psi as stated on the tire sidewalls when using the FEL. Since I use it a lot (I load lots of horse pucky on the farm) I always keep them at their max.
Again, this is just for the front R4's. :thumbsup:
   / Tire Pressure With a FEL #8
I run mine at about 40 to 45 psi all the time as I also have my FEL on all the time.
   / Tire Pressure With a FEL #10
I run my front tires at the maximum indicated on the sidewall with the FEL. Have done that for years with no failures.
2000 Ford Ranger (A50515)
2000 Ford Ranger...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
40' Sea Container (A50774)
40' Sea Container...
Bale Ring (A50515)
Bale Ring (A50515)
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
