Tires Tire pressure and front wheel drive lever for YM1601D
   / Tire pressure and front wheel drive lever for YM1601D #1
frankmako
Bronze Member
North Georgia
Ford 4610, Ford 3910 and YM1601D
For a YM1601D, What is the front and rear tire pressure for rice tires?? When the front wheel drive lever is toward the rear of the tractor is the
tractor in 2-wheel drive? When the lever is forward toward the front
of the tractor the tractor should be in four-wheel drive??? Yes I am going to get a manual for the tractor.
Frank
   / Tire pressure and front wheel drive lever for YM1601D #2
lever forward = 4wd
lever back = 2wd
   / Tire pressure and front wheel drive lever for YM1601D #4
Your optimal tire pressure will vary depending on soil conditions and if you have a loader or not. Tire pressure stamped on the side wall is usually max pressure for the tire. I have found that 13-17 psi works very well with my methanol/water filled tires working in my soil type. Also depends on how heavy you implement is and what you are doing with it. Traction requirements are different between a boxblade and a mower. My fronts are usually filled to 25 psi or so. When you have a full loader you want them pretty perky as it makes them easier to turn under load...
VT
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
LOT NUMBER 250 (A53084)
LOT NUMBER 250...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
