Tire plug kit recommendations?
   / Tire plug kit recommendations? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
Anybody have any recommendations for a good tire plugger kit?
Had a bad mowing job the other day that is haunting me. Bearing and/or flange on my flail broke, had a fitting for my tilt cylinder come loose. Went out to the barn today & found the font tire flat & off the rim. Got it the bead reseated with a ratchet strap & my air compressor to find a nice leak where it got punctured. Took it into Les Schwab & they plugged it. Didn't bother charging me for it. So I get home & move a few things around & find a damp spot on one of the rears loaded with bio ballast, yay. I should really have a plug kit in my toolbox so I can at least limp it home, or at least stop the bleeding of not terribly cheap bio ballast if I get a major puncture.
   / Tire plug kit recommendations? #4
I have had great luck with the cheap plugging kits- I've plugged my car/truck tires at least 10-15 times over the years with no leaks or further issues. Just get one with a T- shaped handle rather than a handle shaped like a screwdriver handle.
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
Komatsu PC138 (A50490)
2020 KUBOTA RTV...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
