Tire Options and Advice needed
   / Tire Options and Advice needed #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
Well....I am the proud new owner of a YM2020D.
I ran it a bit today on my grass and the AG tires tore it to shreds. Of course it didn't help that at one point I had the parking brake set and dug myself a hole in reverse:laughing::laughing::laughing:
So....I have 9.5-24 on the rear and 6-14 on the front.
Questions:
1. What are these tires and rims worth if I find someone willing to trade my Ag's for their turf's?. Anyone interested?????
2. I cannot afford the $1600 + shipping price tag at this time for new Rims and tires at Hoyes.
3. Did any other tractors (Deere, Kubota etc use these tires/rims with the same bolt pattern and size that I could look for used?
Much Appreciated
   / Tire Options and Advice needed #3
9.5 24 is what I have on my YM 2000 so a ym240 sold by JD should work for you;)
Same Bolt Pattern with the JD?
   / Tire Options and Advice needed #5
Yeap!
   / Tire Options and Advice needed #7
Then don't drive on the lawn. :D:D:D
I have read there were special turf tires made to fit those narrow rims. Dunno if they are still available, or what to do on the front.
If you do a straight across tire/wheel swap with another Yanmar owner you both might need to change the front axle ratio too. I think my YM240 (YM2000) parts manual shows several ratios depending on tire choice.
Getting a riding mower might be cheaper than converting tires.
Seems my tractor could use the 25 X 8.50 - 14 in front and 13.6-16.1 in the rear for turfs. I don't think I would have to change the ratio....right?. I also looked up the spec's on a Yanmar YM226 and these size turf tire was an option on that model. Wondering if John Deere or Kubota used these sizes at all. I wonder if there are any tractor yards with some of these available in the Northeast.
I wish I could not run this over the lawn but.....
Any idea what a set of these R2's are worth? Also - Can I cut the lugs down to minimize the impact on the lawn? Just trying to think of my options....
Even the links to Ken Jones tires would cost about $1000 for a new set of tires....Can anyone say OUCH!
   / Tire Options and Advice needed #10
Rolling circumference of the tires is the key to maintaining correct ratio. I do not know what your ratio is. If it were me I would want to keep the ratio close to correct. There is a simple formula for finding the correct ratio if you know your front to rear ratio and tire circumference. I believe these tractors are to have 1 to 4 per cent lead on the front tires. If you know or can find the circumference of the tires you now have and the tires you are listing you can run that formula and find whether they would work or not.
Allis Chalmers Disk (A50515)
Allis Chalmers...
2003 Lincoln Aviator (A50515)
2003 Lincoln...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
