Tires Tire Mounting
   / Tire Mounting #1
richn
I need to replace the rear rim on my MF 202. the Tire size is 14.9 X 24. How difficult is it to re-mount the tire ? whould I be able to work the tire off with 2 pry bars and remount it myself ?
   / Tire Mounting #2
I have a brother in the tire and automotive/ag service business. Breaking the tire bead loose from the rim is the most difficult part of dismounting tractor tires. He has an air powered ram bead breaker on his service truck. Without that a heavy hammer and a blunt, flat bar combined with sweat and time. They can be stubborn if they've been there for years and the bead seats on the rim are rusty. Once the bead is freed from the rim seat the job is easier. Three tire tool/bars; start with one, then the second, then the third (all spaced a few inches apart). Then remove the middle and get another bite past either of the two end bars until you have worked your way around. Take the tube out (hope it isn't stuck to the rim). Then do the same for the other tire bead. Just be sure to take both sides of the tire off the same side of the rim - just kidding, that's obvious. Oh, generous application of tire lubricant is also indicated.
   / Tire Mounting #3
Look at the Gemplers site and under product search type in "changing tire". It has general instructions along with pictures showing how to change a tractor tire. They also have a rachet type bead breaking tool along with other tire tools.
   / Tire Mounting #4
Like Fred said, breaking the bead loose is the hard part. And when I just have not had any of the "proper" tools for the purpose, I've laid a tire and wheel on the ground and very slowly and carefully drove a car or pickup front wheel onto the tire without getting onto the rim. Sort of a last resort, but it's always worked for me.
Livestock Oiler (A50515)
Livestock Oiler...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
1265 (A50490)
1265 (A50490)
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
