Tire loading question
   / Tire loading question #1
kyles974
Florida/Alabama area
John Deere 2320 with 200cx FEL...RM550 Woods Finish Mower...GradeMaster Grader....Ratchet Rake
Done alot of reading on filling rear tires. I know there is alot of info on this subject but didnt see any doing it this way...
I live in FLorida, so water is what Im going to use.
This is how I was thinking of filling?
Jack tractor up just enough thatt he load of tractor is off tires, but still have tires touchuing ground.(help prevent tire of comming of bead)
Buy this Installing Liquid Ballast in Tires | Gempler's (allows air to escape why tire is being filled with hose)
SEt tire at 10-11 o'clock. turn faucet on. once water starts to come out of air hose, then turn wheel to 12 o'clock and carefully watch until over rim, which I would think is the 75% filled?
Does this sound safe? and what PSI would you run after water is in tire?
On JD 2320 carlisle nylon trac chiee 12-16.5 tires
   / Tire loading question #2
You Betcha.
   / Tire loading question #3
If you turn your valve stem to the 10/11 o'clock position, the fluid should be over the rim when it comes out after filling.
Put the same amount of air as you would, if the tires were dry.
JOHN DEERE WHP48A LOT NUMBER 107 (A53084)
JOHN DEERE WHP48A...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
