Tire inflation
   / Tire inflation #1
farmdog
I have a low rear tire on my JD 5310. Tried to inflate it with a small compressor but could not get the chuck to depress the valve stem core. Also tire guage would not depress the core of the stem. Do I need a special chuck? Can I inflate the tire with a small compressor like ones used for cars.
thanks for any help, farmdog
   / Tire inflation #2
That should take a standard valve stem/core. The cores screw in, so it's possible it's screwed too far in. Use a small pin, screwdriver or something that will fit within the valve stem and give it a push. You should hear air coming out (maybe a bit if liqiud too, if those tires are filled). If the tires are filled, I suggest you rotate them until the valve stem is at 12 O'Clock.
It's also possible the core is no good. There is a tool used to remove valve cores (it's also used to to chase the threads). This is available at most auto parts stores (maybe Walmart or TSC too). Surprisingly, it's call a "Valve Core Removal Tool". Pick up a half dozen or so valve cores too.
As far as the compressor..yes, you can use a small compressor but it'll take more time due to the volume of air required in the tire.
Good luck!
   / Tire inflation
Thanks for the advice, espcially about rotating to 12 o'clock. Getting late in the day so will have wait until I get my cataract surgery Monday.
thanks, farmdog
   / Tire inflation #4
ps.. if you do remove the core.. jack the tire up to take pressure off of it.. then clean er up.. put in a new core then leave her jacked up to reinflate.. easier on the pump...
soundguy
   / Tire inflation #5
FYI I've found that I have two sizes of stems. So if your chuck won't fit on the stem you might need an adapter.
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2010 FREIGHTLINER M2 BUSINESS CLASS CAB AND CHASSIS (A52472)
2010 FREIGHTLINER...
HARDEE RD60M LOT NUMBER 157 (A53084)
HARDEE RD60M LOT...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
John Deere S780 Combine (A53342)
John Deere S780...
