Tires tire ideas
   / tire ideas #1
Adam33
Fayette Co. Tx.
Ford 4600
I have a Ford 4600 with 7.50/16 with three ribbed tires. These tires are cutting deep and wide regardless of how slow/shallow I turn in sandy loam soil.
Local tire man says truck tire will help. Any suggestions on a tractor tire that works well in this soil? Will the truck tire fix work as well?
<font color="red"> </font> If it looks easy it's hard and if it looks hard it's impossible.
   / tire ideas #2
I'd sure try the truck tire thing - if you have problems with that - you could also get aircraft tires from a place in Houston. ... Genesco ... i think.
   / tire ideas #3
Truck tires will work fine. If unit has a loader, load capacity of truck tires is higher than tractor tires, so you get added benefit there. Have put truck tires on front of 2wd units several times, no problems.
BTW, check the highway mowers, almost all of them will have truck tires on the fronts.
Hope this helps.
   / tire ideas #4
You can also try 4 rib tires as they give you steering still but don't put all the front weight on a single rib.
Firestone 4 rib
   / tire ideas #5
Another advantage of truck tires is the thicker casing that resists thorns better. 3-rib tires seem to attract them magnetically.
Jim
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
(9) SHANK ALL PURPOSE PLOW (A51243)
(9) SHANK ALL...
POWER CORD W/ REEL, 12G WIRE, VICE (A51244)
POWER CORD W/...
2018 BOBCAT E55 EXCAVATOR (A51242)
2018 BOBCAT E55...
