Tire Chains
   / Tire Chains #1
mike194
Northeast South Dakota
AGCO ST30X
I have been thinking about getting some tire chains for my tractor, I would fill the tires but in the summer when i mow the lawn i dont want to leave tracks.
I would like to chain all 4 tires, where is a good place to buy tire chains and also what type is preffered ?
   / Tire Chains #2
there are several posts out there that discuss this if you try a search. I know that there are folks out there that chain all 4, but a dealer told me not to chain the front as it would/could wear out the front end prematurely. one of the sites that sells chains is tractortirechains.com. the style or type that is available is or may be governed by your tire size.
   / Tire Chains #3
Many discussions on this. DON't put chains on the front wheels of a FWD tractor. That is unless you like buying new front drive line parts.
Andy
   / Tire Chains #4
www.tirechain.com
I have 75lb of fluid in each rear tire of my 2210 and mow with it. I mow some steep slopes and love the fluid for stability. I don't notice the weight being hard on my lawn but my tractor weighs around 1000lb so I can't mow when it's extremely soft anyway.
edit: forgot to mention I use V-bar 2-link style chains and only chain the rear.
   / Tire Chains #5
I disagree - I think it's ok to use chains on the front (in slippery conditions); if you use FEL you'll have trouble without front grip. My argument is that there's not more relative grip on front end with chains than with regular tires on gravel and almost everyone uses MFWD in that scenario - actually I get more slip with chains on packed snow than R4's on gravel road.
   / Tire Chains #6
Chain all four up if you will be on steep paved hills that are icy. Otherwise, the unchained end just slides around.
I like the V-Bars style but they do make a mess of asphalt. In fact all chains make a mess of asphalt. This year I'm studding my tires and going with out chains for as long as possible.
I buy most of my chains from tirechains.com and have always gotten good service and pricing.
   / Tire Chains #7
+1 to the steep hills - but in midwinter it doesn't matter around our place if paved or gravel underneath since you're operating on a couple of inches of hardpack snow/ice anyway (whic is desirable for not plowing/blowing your gravel anyway)
   / Tire Chains #8
I run tire chains on all four of my tires. Chains make a HUGE difference.
If your tractor is small enough, you can get truck tire chains that fit for about half the cost of tractor tire chains.
This past weekend I just was looking through another pile of stuff from an auction and found a set of V-bar tire chains will just fit my tractor. I'm excited to see if they are that much better than the regular chains.
   / Tire Chains #9
i think the chains on front and 4wd on dry ground is the same principal. both "can" provide too much grip and with that grip when turning you can cause premature wear. Same thing they warn you about when using 4WD with a vehicle on dry ground. I would say that the slippage would be a good thing and if you are using chains on the front in snow or ice it will give you that slippage. if you are chaining the front and driving on dry pavement or where the tires are grabbing that can cause the wear on the front end.
   / Tire Chains #10
I'm with the folks that say only on the back, you wouldn't run 4wd on pavement so why stress the front with chains. I've been plowing snow with rear tire chains on many different types of tractors{even a 2wd drive truck} for over 30yrs and never had a problem/situation where I needed chains on the front. Try it with just the rears 1st you may be surprised?
2021 John Deere 410L Backhoe (A53342)
2021 John Deere...
JOHN DEERE 560M LOT NUMBER 37 (A53084)
JOHN DEERE 560M...
JOHN DEERE 461R LOT NUMBER 61 (A53084)
JOHN DEERE 461R...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
2022 CATERPILLAR 317 EXCAVATOR (A51246)
2022 CATERPILLAR...
