Chains Tire Chains for 4520
   / Tire Chains for 4520 #1
jcmseven
Veteran Member
western NC
JD 2320; 4520
I am interested in buying some tire chains for my 4520 for wintertime. I need some that are easy and quick on and off and that are tight to the wheel. I also noticed that I have almost no clearance between my R4 tire and the fender. Is there any way to scoot the wheel out a bit to give it clearance or do I have to reverse the wheel to get the clearance I need?? Currently, I would not want to put a tire chain in a space that tight. Also, do tire chains on these big tires tend to stay put well, or are there other issues I need to have concern about? I am not concerned about going in snow, it's the stopping I am concerned about. I feel tire chains would offer that added security I need, if they are not too difficult to install.
John M
   / Tire Chains for 4520 #2
You can reverse the tires and gain about an inch of clearance. Not much, but better than what you have.
I did that and then made my own chains, that the side chains would fit in the depression that is at the outside edge of the bars. They work great and do not slip around in use.
Another outside possibility is to see if tirechain.com has chains that would have a narrow or thin side chain that would work. I have a cable chain for my SUV that only has about 3/4" room between the emergency brake cable and the tire. The side 'chain' is actually a cable, and they go on/off very easily. Can be seen on tirechain.com also, but I don't think they would work for the big R-4 tires in snow and on ice.
Last resort would be to add spacers to move the tire further out. But I don't think there should be a problem, as long as the tire chains don't fail and one ends up with a broken link that would catch the fender. Not a pretty thought. /forums/images/graemlins/crazy.gif
2015 Nissan Pathfinder SV SUV (A50324)
2015 Nissan...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
John Deere 260E DOBBS Off-Road Dump Truck (A50322)
John Deere 260E...
TARTER INDUSTRIES 7' ROTARY TILLER (A51243)
TARTER INDUSTRIES...
Irrigation Pump (A52128)
Irrigation Pump...
