Tire chains for 44x18-20 turf tires - what size and how to properly mount?
   / Tire chains for 44x18-20 turf tires - what size and how to properly mount? #1
Jerry1
Bronze Member
I've got 44x18-20 turf tires on the new/old JD 1070 FWD I bought. I will be using it to clear snow from my gravel driveway and I'm thinking chains would be a good idea. I see that the chains are offered in 5/16 or 3/8 inch sizes. What should I get for use on a frozen gravel driveway? Also, what is the proper fit for the chains? I've read posts where you need to tailor fit new chains to your tires, but is that normal if you buy them for your specific tire size? And what is the proper fit? Tight with no slop to the chain or what? With the big turf tires I have I don't have a lot of room for a loose chain to move around before it would hit the inside of the fender.
Thanks for your advice. This forum is great for us that need help like this.
   / Tire chains for 44x18-20 turf tires - what size and how to properly mount? #2
   / Tire chains for 44x18-20 turf tires - what size and how to properly mount? #3
My concern with screw-in studs would be that they might fall out and end up in another tire that I don't want them in! :eek:
Are my concerns valid?
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
