Chains Tire Chains (Again)
   / Tire Chains (Again) #1
JudeK
Connecticut
BX2200
Happy holidays to all!
I want to use my BX2200 to clear snow this winter, using the FEL and a box blade for counter weight. I've read through dozens of tips concerning using a rear blade, but at this point I don't have $300+ for the blade and was considering purchasing chains instead.
I have the standard turf tires on the BX and have gotten stuck in mude with those, so I think chains would be a plus in the snow.
I have roughly 200' of gravel drive to plow, 25' wide at the garage, then 10-15' the rest of the way.
I know this topic has been beaten to death, but I'm not sure what to do. Duo-grips, 2 link, 4 link? What size for the BX turf tires?
   / Tire Chains (Again) #2
Go to this link Tirechains.com and call their 800 number. They're very helpful people and will recommend a solution. Plus they're prices and shipping are reasonable. All you need to have is your tire size and a credit card if you buy.
Terry
   / Tire Chains (Again) #3
I have a BX1800 with turf tires and I bought tire chains from my dealer for $110. I've been on some snow and mud with the chains and didn't have a problem.
   / Tire Chains (Again) #4
With turfs, I'd personally avoid Duo-Grips. With the flat profile of the turfs, they'd give you a very bumpy ride! On my old B1750 with turfs I used 2-link spacing on ladder chains and got pretty good results.
Pete
www.GatewayToVermont.com
   / Tire Chains (Again) #5
I followed the advice I found on an older thread on the same topic. I got in touch with tirechains.com. Received my set of chains for my BX2200 just a week before our most recent Minnesota snow job.
I got the standard 2-link spacing chain for both front and rear - not the v-bar. They work great. The 2-link gives really good grip, and a smooth ride - on snow. The ride's a bit bumpy going across the concrete barn floor!
The chains fit perfectly. I had to cut 2 or 3 links off after I got them on. The only minor problem I ran into is that the front chains can rub on the steering nuckle if they aren't put on just so. Not a big deal.
At the advise of Tirechains.com, I also bought and installed chain tensioners. That's the first time I ever used them. I don't really think their needed on chains as small at the BX takes. I was able to put them on plenty tight by hand. But being as they were recommended, and I had them, I used them.
I plowed about 800 ft of drive with 6" of good Minnesota dry snow up a 40 ft hill. No problem.
Ed Neu
Buffalo, MN
Thanks to all -
I'm going to give Tirechains.com a go and get the two link. Carver also has two link chains for $110, but judging from your replies, Tirechains is the way to go.
   / Tire Chains (Again) #7
I think you'll be happy with your choice and I agree with Boondox re the ladder type for turfs. I use the duogrip bbut only because I have R1's and the ladder type would fall between the lugs
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
2008 CATERPILLAR 140M VHP MOTORGRADER (A51242)
2008 CATERPILLAR...
2012 Ford F350 Bucket Truck (A47384)
2012 Ford F350...
CASE IH MAGNUM 180 TRACTOR (A51243)
CASE IH MAGNUM 180...
KUBOTA L4600 TRACTOR (A51243)
KUBOTA L4600...
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
