Tire chain size???
   / Tire chain size??? #1
LD48750
Veteran Member
SE, MI
Ford 1510 Mahindra 1526
What size chains do I need for a 11.2 x 24 R4 tire?
Length of side chain & cross chains.
Same question for a 13.6 x 16 turf tire.
Got assorted chains and just need to cut to size.
New are too expensive for what I am going to be using them for.
   / Tire chain size??? #2
Can't give you a number, but what I did with old chains I had that I was changing from 4 to 2 link, and fitting a smaller diameter tire, was I readjusted the cross links to 2 link starting at the end with the locking link, then after I got a bunch of cross links added where I wanted them, I put it on, and hooked them close, and cut the extra off ...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56435)
2023 Kubota...
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
2022 Horizon Trailer (A55973)
2022 Horizon...
