Tire Ballast
   / Tire Ballast #1
Hinomotoman
Western NC
LS R3039, Hinomoto E2604, Hinomoto N239, Case IH 1140, White Field Boss 31
Does anyone know the capacity of the 43X16.00X20 tires? I put 20 gallons apiece in them yesterday but don't know how much more I need.:confused:
Eugene
   / Tire Ballast #2
I haven't found a tire chart with that size (same tire on my tractor). Liquid tire ballast should be close to 75%. A tire that is close is a 41x14-20 which would use 32 gallons for a weight of about 267Lb. per tire. With the 43x16-20 a little larger I would think around 35 gallons per tire would work fine. I still haven't decided whether to load mine yet. If I do I'd put 35 gallons of washer fluid in each of mine which should be at least 280lb. per tire. At 20 gallons each your probably about 160lb. or so per tire. Try it out, you can always add more later. What did you fill them with?
   / Tire Ballast
Antifreeze/water solution.
Eugene
   / Tire Ballast #4
I used one of these and 1 gallon of antifreeze Per tire. turn tire valve to the top and fill, when water starts to come out of the hole it is correctly filled.
Quick Fill Tractor Tire Attachment - GEMPLER'S
Sent from my DROID RAZR HD using TractorByNet
   / Tire Ballast #5
Just filled mine. 38 gal per tire. I used the rimguard chart to figure that out before I went and cleaned out the store of RV antifreeze.
Eugene
   / Tire Ballast
Thanks hutchman
Eugene
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
Blue Diamond Quick Attach 6 Way Blade (A50514)
Blue Diamond Quick...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
CATERPILLAR GP30 STRAIGHT MAST FORKLIFT (A51242)
CATERPILLAR GP30...
