Tire Ballast
   / Tire Ballast #1
fwc
Bronze Member
Near Atlanta, Georgia - USA
Kubota BX25D
It the reason people use calcium cloride for tire ballast beause its heavier or cheaper than the same amount of water/antifreeze?
From what I have read, it tends to corrode rims somewhat so what is the advantage.
Floyd/fwc
   / Tire Ballast #2
<font color="blue"> Is the reason people use calcium chloride for tire ballast beause its heavier or cheaper than the same amount of water/antifreeze? </font>
It's heavier, but not cheaper than water/anti-freeze.
<font color="blue"> From what I have read, it tends to corrode rims somewhat so what is the advantage. </font>
In some cases it does while others have had it in their tires for years without a problem.
The advantage is that it's heavier per gallon than many of the alternatives.
Many people use windshield washer fluid instead, while others use wheel weights.
   / Tire Ballast #3
Hi...
There are newer types of liquid tire ballast that are non-corrosive and non-toxic...
If calcium chloride is used... tire tubes are recommended...
Dave...
   / Tire Ballast
Mike,
All the talk about Slime and such in another thread got me curious. Thanks for the response.
Wheel weights seems like the way to go cuz you can yank them off if you decide to. Filling tires up with junk seems kinda permanent.
Tnx,
fwc
   / Tire Ballast
I guess filled tubes makes sense to eliminate the rim problems.
Oh well thanks for the education.
fwc
INGERSOLL RAND INDUSTRIAL AIR COMPRESSOR (A51248)
INGERSOLL RAND...
2025 JMR 36in Bucket Skid Steer Attachment (A51691)
2025 JMR 36in...
2005 GENIE Z-45/25 TELESCOPIC LIFT (A51246)
2005 GENIE Z-45/25...
2019 JOHN DEERE 8245R LOT NUMBER 173 (A53084)
2019 JOHN DEERE...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
