Tire Ballast
   / Tire Ballast #1
weehawl
Kubta L-3200DST 4x4
Thinking about adding antifreeze to rear tires on my L3200 Kubota. Rear tire size is 27x8.5-15 R4. I have the equipment to fill the tires but would like to know about how much water volume is required. If anyone can pass along a formula to calculate the water volume it would be appreciated. Thanks
   / Tire Ballast #2
diameter / 2 = radius
radius x radius x 3.14 = square area
square area x height = cubic volume.
cubic inches / 12 / 12 /12 = cubic feet
cubic feet x 7.48 = liquid gallons. (conversion between feet to gallons)
other words...
27 / 2 = 13.5 radius
13.5 x 13.5 x 3.14 = 572.265 square inches
572.265 x 8.5 = 4864.2525 cubic inches
4864.2525 / 12 / 12 / 12 = 2.8149609375 cubic feet
2.8149609375 * 7.48 = 21.0559078125 gallons
above does not take into account area of rim. that you would need to subtract from 21 gallons. but same math as above to figure out rim space.
i am sure there is a better formula to figure out "donut" shape. but above will give you a rough estimate.
   / Tire Ballast #3
Our just Google - Tire size water capacity and it is already figured for you.:D
   / Tire Ballast #4
You may want to look at RV antifreeze or windshield cleaner
for your tires. Both are less toxic then regular antifreeze and
less expensive. The tire size has me puzzled as I looked on line
and found this scale. I may be missing something, but by this
scale the tire will not hold that much.
www.tractorsmart.com/Farm_Tractor_​Liquid_Tire_Ballast.htm
   / Tire Ballast
Thanks guys for the info. Will get started asap.
   / Tire Ballast #6
A simple call to your local tractor dealer will answer your question. When asked about Rim Guard every dealer told me how much the tire would hold, the weight, and the cost. Keep in mind Rim Guard weighs more but the volume would be the same.
   / Tire Ballast #7
I couldnt find that tire size on any charts so I calculated it by extrapolation of cylinder volume based on 27" OD x 8.5" high minus a 15" x 8.5 cylinder and came up with 12 gal. capacity @ 75% fill = 9 gallons of liquid capacity for this tire. That figure may be a little high.
   / Tire Ballast #8
FirestoneAg and GoodyearAg web sites have tire capacity tables for this.
Not sure if they go down to such a small tire - they may consider it too small to be worth filling ...and they may be right about that (-:
I went for RimGuard in my little tractor, with 17.5Kx24 R4s.
It came to a little over 100 gallons for the pair and that made a BIG difference to a tractor that was previously only about 5,300 lbs with it's loader.
It didn't make it a Cat 3 or Cat 2 tractor by any means - maybe Cat 1.4 (-:
   / Tire Ballast #9
Here is what chart on Balastar.com show.
Tire Size Gallons of Liquid Calcium. Weight (lbs.)
27x8.50 - 15 7 74.9
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
(3) 55-Gallon Drums of Fertilizer (A51573)
(3) 55-Gallon...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
