avc8130
Platinum Member
I set out to ballast the rear tires on my Kubota L45. The rear tires are 15-19.5. According to most ballasting charts I found, they should hold 29 gallons. I started pumping and put 30 gallons in each figuring I'd drain out the extra gallon once I pulled the hose to know I was at the valve stem at 12 o'clock.
Well guess what? I removed the hose and got nothing. I rotated the tire slowly until I saw ballast coming out, the tires are filled to ~10 o'clock.
Should I keep adding ballast until they are filled to 12 or is there a reason the charts list 29 gallons?
Thanks!
ac
PS: I used -20F WWF for ballast.
Thanks!
ac
