Tire Balast
   / Tire Balast #1
Ffphil
Buckley, washington
Yanmar YT359C
What should I get, beet juice or non corrosive? This may be the same thing and I'm confused.
   / Tire Balast #2
Do you need rear tire ballast for a 22-horsepower tractor?
Beet Juice is dense and non-corrosive.
   / Tire Balast #3
Beet juice/Rimguard is the heaviest/gal and is non-corrosive. It is also the most expensive per gallon but is still far cheaper than steel on a lb/lb basis. Many guys use windshield washer fluid as well (WWF).
   / Tire Balast #4
I plan to get Rim Guard for my small tractor if I can find it. It gets "floaty" in the rear with a lot of rocks or dirt in the bucket. The tires won't hold much but any is better than none. I might add some wheel weights, too.
   / Tire Balast #5
If you do decide to load the rear tires - get something non-corrosive. Rimguard(beet juice) - windshield washer fluid - recreational vehicle antifreeze. I would STRONGLY recommend against any salt product - the hassle, potential damage and bother are just to great.
   / Tire Balast
We are looking at a 60 hp tractor. The rimguard/beet juice will add a little over 500lbs per tire. They say 55gal/tire.
   / Tire Balast #7
Add the model of your prospective tractor to your T-B-N profile so your posts make sense.
   / Tire Balast #8
First thing: Call Rimguard and tell them they're the biggest forking idiots on the planet. Ask them where their on-line list of retailers/installers is on their web site. When they give you the "no speak da engrish" routine, tell them they are forking idiots. It's the 21st Forking Century already! Who in the world has a website without a list of locations in this day and age???
Then ask if there any retailers/installers in your area. There should be, certainly in Eastern WA, not sure about Western. The closest place they had when I called a couple years ago was north of the TN/KY border, about 125 miles from me - one way. You can't buy a barrel or two, you have to physically take the tractor or tires to the installer. If it's just the tires, good luck installing +600 lb tires when you get them back.
I haven't checked to see if there are any new ones closer to me since then - why? Because those forking idiots won't put an on line list on their stupid website, you either have to call or e-mail them. Forktards.
If the question is: Fill the rear tires? The answer is: Yes.
If the question is: With What? The answer is: Rimguard - if you can get it.
The one disadvantage (cost) of Rimguard is way outweighed by all the advantages (weight, temps, non-corrosive, non-toxic). Except of course, if you can get it. And the cost of Rimguard has nothing on metal wheel weights.
Types of tire ballast: Comparing Types of Liquid Tire Ballast | OrangeTractorTalks
Why do it all: 6 Reasons to Liquid Ballast your Kubotaç—´ Tires | OrangeTractorTalks
How to do it (except if you go the Forking Idiots route):How to Ballast your Kubotaç—´ Tires | OrangeTractorTalks Note: If you use straight water (not recommended), you use a garden hose off your water hydrant. If you use a mix, like water/RV antifreeze like I did, then substitute a 5 gallon bucket (or bigger) and a small pump, like a sump pump with a garden hose outlet. Either way, you'll need that hose adapter to "burp" air out of the tire. See pic below.
   / Tire Balast #9
I used windshield washer fluid 15 years ago. It's still in there and I haven't had a leak yet, knock on wood. It was about 1$ per gallon on sale at the time. I used a $10 drill powered pump that I still have and still use from time to time. Make sure the valve stem is at 12 oclock and release air with fluid flow slows.
Kevin
   / Tire Balast #10
I put 65 gallons of WW fluid in each of my rear tires. If you go that route, I suggest you find out who sells it in bulk to the quick lube places in your area.
A 55 gallon drum of methanol is about $180. Mixed 3:1 with water gets you about -18* of protection.
Best part was delivery was included.
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
(INOP) NISSAN MU1F2A25LV WAREHOUSE FORKLIFT (A51243)
(INOP) NISSAN...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2019 MDB FM180 FINISHING MOWER (A51243)
2019 MDB FM180...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
