Tire Advice
   / Tire Advice #1
smoker
Bronze Member
Central NYS
Kubota B9200
I have a B9200. I use it for general stuff and am not satisfied with the turf tires it has on it. I use it on my lawns for rolling and general clean up so don't want a tire that would leave cleat marks. Does anyone have experience with a different tread style that might give me a little better traction? Thanks much, smoker
   / Tire Advice #2
"Better" traction may well lead to deeper marks, it can be a trade-off.
There are several different "turf" tires, or R3 tread patterns.
You might try browsing the tire manufacturers themselves and searching for "Golf" and/or "Galaxy" tires.
By "Golf" they mean fairways, not putting greens (-:
I have always found FirestoneAg and GoodyearAg to be good places to start - one of which is now "Titan", but you can still get to the old web pages.
   / Tire Advice
Thanks Reg. I'll check em out. I've been skidding logs and the lack of traction is frustrating to say the least. smoker
   / Tire Advice #4
Seems like tire chains would serve you well. Chains for that size tractor would be of a easy to handle weight and would remove fast when you hit the grass. Best of all you wouldn't need new rims.
   / Tire Advice
That's a thought Wolfy. Suppose that would be a special order? smoker
   / Tire Advice #7
You can just ask he dealer as well. Chains are most often made for a range of tire sizes. If yours happens to be on the smaller end of the range you might have to remove a few cross links. I recall having read about three turfs threads and I used to have the middle of the road of those three. It worked quite well and only left marks in the sharpest turns. If you put chains on turfs they make a huge difference in the soupy mud or snow.
I recall having seen pictures of three or four different threads on turf tires. Here is a post that shows two of the three or four tire/thread designs.
www.tractorbynet.com/forums/john-deere-buying-pricing/97039-turf-tire-fine-turf-questions.html
   / Tire Advice
Thank you all very much. Iwas stunned when I asw the price of new tires. Chains are sure the erasier/less expensive way to go, although I have to use a blacktop driveway often and wonder about damage. Did see a pair of ag tires mounted on 9200 rims from a place in Ontario, he's asking 500.00 for the pair. Thanks again
   / Tire Advice #9
Turfs accept chains fantastically, because of the flat tread profile. And in the woods, chains on turfs are way better than Ag tires.
   / Tire Advice #10
Smoker, you didn't say if your tractor is a 2wd or a 4wd. Keep in mind, if it is a 4wd, and you get the R-1s for the rear, you will also need to change the front rims. If it is a 2wd, it won't really matter, although it could change how level the tractor sits.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
