Tips on using flat deck trailer for hauling stuff to the dump?
   / Tips on using flat deck trailer for hauling stuff to the dump? #1
sheamus
Upper New Cornwall, NS
Bobcat CT2035HST
Any tips on using flat deck for hauling stuff to the dump. I am going to build some small sides, but would be nice if unloading at dump wasn't such a pain. I don't have a dump. I am thinking a few totes that I could tip over the side may be the best... that allows me to group steel, lumber, etc, together so it goes in the right pile. Hauling to the dump is a lot cheaper if you use the correct piles here.
   / Tips on using flat deck trailer for hauling stuff to the dump? #2
Depends on what you are hauling.
Maybe lay some long tow straps on the deck from right to left (not front to back). Then lay a tarp on top of the straps. Then put all of your stuff you are hauling on top of the tarp. Then tarp/strap everything down as you normally would for the drive.
At the dump, take off your top straps/tarp. Then grab the underlying two straps from,say, the left side over the top and pull the tarp over to the right side, thereby dumping everything that is on the tarp to the right.
   / Tips on using flat deck trailer for hauling stuff to the dump? #3
Those truck cargo nets are an ideal way to secure the tarp on the load.
   / Tips on using flat deck trailer for hauling stuff to the dump? #4
For sure placing an old tarp on the trailer bed will quicken clean up.
From there you can upgrade by making or buying a rear tarp roller so you simply crank and roll your load off.
They even sell them as a 'truck bed' unloading kit.
   / Tips on using flat deck trailer for hauling stuff to the dump? #5
It depends what you're hauling but you can buy used billboard signs for pretty cheap like 80 bucks for a 14x48. its smooth vinyl, so you can drag the load off pretty easy and its much more durable than normal tarps.
   / Tips on using flat deck trailer for hauling stuff to the dump? #6
Huh.. never though of that.
I wondered about something like that. I was thinking of bring a stake to pound in, and tie to sheet, then drive ahead to pull it off if it proved too heavy to pull off by hand. But rigging something up with a winch may ne easier.
   / Tips on using flat deck trailer for hauling stuff to the dump? #8
My friend uses a tarp with straps under it as Seville009 described. The loader operator at the land fill grabs the end of the strap nearest the tongue and pulls the load off by rolling the tarp over for a $20.00 tip.
   / Tips on using flat deck trailer for hauling stuff to the dump? #9
My solution for wood. Hindsight has me extending the sides back over the axels. The Amish gent I bought wood off this year refuses to take a refund for 3 ricks I got from him. Got it home and split it up, ended up with a cord and a half. Any who, that box is about 122 cubic feet and a cord is 128 or so.
INSPECTION (A51573)
INSPECTION (A51573)
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52141)
2015 VOLVO VNL...
Year: 2021 Make: Acura Model: RDX Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 57,499 Plate: (A50324)
Year: 2021 Make...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
