Tips on Harley rake use and adjustment
   / Tips on Harley rake use and adjustment #1
Larry_Van_Horn
Honeoye Falls, NY
Case 580D Backhoe, NH TC40D SS, JD 450BC dozer, Ford F700 dump
Folks,
I have rented a Harley rake for the weekend, and spent 4 hours this evening with it. I am preparing my grass seed bed, about 2 acres. The Harley rake is doing a nice job, but I am not sure that I am setting it up right. In particular how should the toplink and guage wheels and 3 pt depth be set so that I kick the rocks and not overly rototill the ground.
Second once I have put down the grass seed would you roll it in, use my chain harrow to drag it in? THanks,
Larry
   / Tips on Harley rake use and adjustment #2
I found the rake will let you know how deep it's willing to go depending on how hard the ground is. They are not very useful when the ground dries up in the summer. The biggest adjustment is the blade on top that dictates what size rocks it will pass thru. Don't make the mistake of dropping it too low (small gap) as this will slow you down to a snail's pace.
The rake leaves a perfect bed for grass seed. Seeding and rolling is the best. If you want to chain harrow for to smooth things out I'd do that first, then seed, then roll.
That's just the way I'd do it /forums/images/graemlins/grin.gif
   / Tips on Harley rake use and adjustment #3
I agree with Steve's info. I'll just add one thing. My father and grandfather were nurserymen and the one thing they said about putting in lawns was that most people rolled with too heavy a roller and didn't give the seed a chance to breath. Of the hundreds of lawns we put in, we always used a empty roller (very light) and had great results. To cover the seed before rolling, we often used a very light touch on a push broom jsut to mix up the soil with the seed.
Andy
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
20711 (A51694)
20711 (A51694)
2009 Kubota RTV1140 (A50123)
2009 Kubota...
Bobcat Sweeper/Bucket  72"  (A52384)
Bobcat...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
