Box Scraper Tips for flat driveway
   / Tips for flat driveway #1
Rgladden
Just looking for suggestions to spreading crushed concrete for driveway.
   / Tips for flat driveway #3
What do you have for implements? How thick are you wanting to spread it? Existing drive or are you installing a new drive?
   / Tips for flat driveway #4
Everywhere I used crushed concrete, horrible weed problems happened. I would consider modified. Where I used modified, there were some weeds, but far less.
Anyway, My tool of choice would be a small bulldozer. Next would be a tractor with a loader and wide bucket and a back blade and then maybe a mini ex with a grader blade
   / Tips for flat driveway #5
Get a bunch of marking shiskers.
Amazon.com : marking whiskers
Place them and grade until all the exposed whiskers are the same length. This keeps you from having 1/2 inch deep in one area and 6 inches deep in another.
Bruce
   / Tips for flat driveway #7
I use my tractor - front bucket - rear blade - LPGS. Of course, I've only ever had to repair my "historic" 100 foot long mud hole. I've never applied new material along the entire length of my driveway. This year I will use my LPGS to correct some lumps/bumps. It will require that the scarifiers on the LPGS be used also.
Timing is very critical. Too soon - the driveway is still too wet. Too late - the driveway has dried out and is just like concrete. My driveway - mile long - comprised of - base cobble - gravel, sand, silt, volcanic ash.
   / Tips for flat driveway #8
Have truck driver tail gate spread as much as he can than use front loader or back blade,finishing touch turn back blade 180 degrees spread.
   / Tips for flat driveway #9
Fabric underneath helps create a barrier between soil and your substrate. Keeps the stone from pushing down into the mud and numerous other benefits if its a new driveway.
   / Tips for flat driveway #10
^This.
Also, not sure if there’s a saying about “a road is only as good as it’s ditches”, but basically water needs to flow in the ditches, not flow on and erode the road. Ditches, crowns, pitch can be important.
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
1963 Trail Mobil Tanker (A50514)
1963 Trail Mobil...
NEW HOLLAND C332 SKID STEER (A51242)
NEW HOLLAND C332...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2004 Ford F250 (A50515)
2004 Ford F250...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A51243)
2004 TRAILKING...
