Tipped tractor wont start
/ Tipped tractor wont start #1
johnecool
Hi,
I have a Kubota ZL1801DT diesel tractor that i managed to roll. I am now having problems starting the engine. When the tractor was turned upright it started for about 20 seconds & then shut off. It now will not start, the engine turns over but nothing. It lost oil which was replaced.
What can i look for to get it going again.
John
/ Tipped tractor wont start #2
Hope you are alright after the incident. No first hand experience here, but I would suggest bleeding the fuel lines. When it was tipped the fuel would have drained out and there is most likely air trapped somewhere in the system. Not familiar with your model, so I can't give you any details- check your manual?
Best of luck, and welcome to TBN.
/ Tipped tractor wont start #3
John, No engine likes to be upside down, least of all a diesel...
How long was it upside down? While in that condition oil is seeping past the rings creating a small pool in the cylinder and if you don't either A: give it a day or so the seep back past the rings or B: remove injectors to release compression and spin motor over to flush the oil out...
It could have blown the head gasket due to lack of free space in cylinder under compression stroke... /forums/images/graemlins/frown.gif
This is a possibility, not what you want hear I'm sure but, if you take your time and check things over between air in fuel and compression you will find it.... Good Luck
/ Tipped tractor wont start #4
A neighbor experienced a "tipping" but not rolling (big woops!). While on it's side the engine ran until it quit & when righted would not turn over. I helped him pull the glow plugs & we bumped the engine 20 or 30 times. The first time great gushes of black engine oil shot out of the cylinders. Towards the end of the process only a mist of oil was coming out. We then reinstalled the glow plugs & it fired right up. Lots of white smoke @ first but it thinned out after the engine ran a while. Hope this helps. Don't forget to top off any lost oil & check for antifreeze in the oil. It might need a total change.
/ Tipped tractor wont start #5
As Nasty said "How long was it upside down?" If it was upside down very long it may have oil in the cylinders.
/ Tipped tractor wont start #6
</font><font color="blue" class="small">( When the tractor was turned upright it started for about 20 seconds & then shut off. )</font>
If the tractor ran that long after being uprighted, then I'd say oil leakage into the cylinders was not your problem. I'd bleed the fuel lines as suggested. Probably air or trash, but I'd bet a trapped slug of air is your culprit.
/ Tipped tractor wont start #7
Yeah, It sounds like Jim has it nailed. 20 seconds is about how long you can idle with just the fuel in the pump. While it was "over", the fuel in the bowl went back into the tank. Then when you ran it, a slug of air got into the line and the pump isn't self priming. Read the manual on how to prime and you should be good to go.
Any chance you are willing to share the details on the roll over?
jb
I will need to find the manual on the internet some where to find out how to prime the fuel line I have no idea. At least this info gives me something to try. It was over on its side for about 45 minutes. Oil had fallen out of the engine via rubber tube.
About how it happened I am new at riding tractors. It was my fourth time riding one.
I had the front tray a little too high & i was on very slight hill going side ways with a slasher attached on the back. I could feel the tractor was leaning over too much. I stopped the tractor & tried to reverse because i didnt want to go any further, once i reversed a little it started falling I jumped off. Not sure if it was the best thing to do but i didnt want to hold on to see what happens. As i was on the ground & the tractor feel the roll bar slightly clipped my ankle only suffering very minor bruising. I consider myself very lucky. I think my biggest mistake was I didnt lower the front tray while driving.
Thanks for the info.....to date.
/ Tipped tractor wont start #9
Could have been bad.. wouldn't want the tractor or roll bar to crush you. Might have been better off seat belted in.
Soundguy
/ Tipped tractor wont start #10
<font color="blue"> I think my biggest mistake was I didnt lower the front tray while driving. </font>
John,
Glad you came through that experience OK.
Since you are new to tractors, it may pay to take some time reading the safety forum. Tractors are wonderful tools and best buddies too, but they can hurt us if we let our guard down.
The rule of thumb is if the tractor has a ROPS, wear your seat belt. Otherwise if the tractor tips, the tractor becomes a mouse trap and the driver the mouse. Mouse traps don't catch every mouse, but they do catch their fair share.
Enjoy your tractor and all the work it will save you and your back. /forums/images/graemlins/smile.gif
/ Tipped tractor wont start #11
Glad to hear you are OK. Dad was notorious for turning tractors over but somehow never got hurt. On priming you may try posting here on the Kubota forum to get an answer specific to your tractor. I bet someone there will help. If not, you start at the tank and end at the injectors. Try to start in between. At the tank you may have a shut off valve that has one or two phillips head bleed screws. Open until no air comes out then close, try to start. The open the fitting on the line that goes into the injection pump from the shut off valve untill just fuel comes out, tighten the fitting and try to start. If that doesn't work, loosen a fitting at an injector, crank until you get only air then tighten that fitting. This is kind of generic for most diesels. Let us know.
/ Tipped tractor wont start #12
</font><font color="blue" class="small">( I will need to find the manual on the internet some where to find out how to prime the fuel line I have no idea. At least this info gives me something to try. It was over on its side for about 45 minutes. Oil had fallen out of the engine via rubber tube.
Thanks for the info.....to date. )</font>
In the "feels like it is tipping" case, stop and drop the bucket and/or any other implement you are carrying to the ground. That should stop the roll-over and give you a chance to figure out a way out of there.
Harry K
/ Tipped tractor wont start #13
One more point. If it gets tipsy, always turn down hill. Most times that will prevent rollover.
/ Tipped tractor wont start #14
Best to keep the bucket as close to the ground as you can when moving, especially with a load. It keeps the center of gravity low helping to prevent what happened to you.
Glad you came through all right, tractors can be fixed, sometimes we can't. /forums/images/graemlins/frown.gif
/ Tipped tractor wont start #15
I'm just wondering if you got it started again. My bet is that the glow plugs were fouled by the oil in the cylinders which would hamper a cold start. That could explain why it re-cranked initially but refused to crank since the incident after it cooled down. So, what do you say? Report in, please.
Tom
Sorry it has taken so long to re post my reply.
I have managed to start the tractor!! yay /forums/images/graemlins/smile.gif The fix was to bleed the fuel line (as suggested by a few poeple) it wasn't flowing properly because there was air in it.
Thanks to all who posted. I have learnt my lesson.
John.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 GPS Trailer (A56857)
2025 GPS Trailer...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
8'X28" Table with sink and dishwasher inlet (A60352)
8'X28" Table with...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
