It's not common practice to take a valve apart and you don't need to.
Ball valves are the most common valve these days and the best for most uses. The proper way to do it is to move the handle to the 45 degree position or fully open, but not closed.
Use flux sparingly! You don't want it trickling down into the valve past the socket. Very little is required and mainly on the pipe itself.
Heat the joint aggressively, but not the whole valve, just the joint you will sweat. Heat the pipe and the socket at the same time. As soon as the socket, where the pipe enters, is warm enough to melt the solder, start feeding it in and keep the heat on it until you get a good flow of solder feeding in. Take the heat away and run the tip of the solder wire around the socket too make sure it has fed in all the way around, knock off any drip. Do not use excess solder, and remember the solder flows toward he heat.
If the pipe is vertical, solder the top first and be careful not to use too much.
Don't get it too hot. If you see black you are way too hot.
Now do the other side.
Now wait until it solidifies, leave it alone a few seconds until it does, (it becomes less reflective) and then spray it with soapy water from a spray bottle until it doesn't boil the spray and wipe it with a wet rag.
It's really very quick and easy.
Use lead free solder if this is for drinking water. Silvabrite is an excellent brand. Use water soluble flux too, if you can. Use emery cloth to clean the pipe and a socket brush or emery cloth to clean the valve. This can be done casually as they don't have to be real shiny.
Do not take the valve apart. Just get in there, do it and get back out without blackening the pipe. Mapp torches are very good because they are hot and you can really get the energy on the spot you want it.
