Tip on Preventing BX Overheating
   / Tip on Preventing BX Overheating #1
Tom_H
Veteran Member
20 mi SE of Sacramento, CA-rural
Kubota BX2200
I spent much of the day brushhogging with the Gearmore HD RC on the BX2200. The weeds were mostly two to four feet tall and most were tinder box dry. There are some noxious things in the mix, like Russian Star Thistle, but much of it is wild oats. The blades pulverize this stuff and the chaff floats around and makes the air into a concoction that resembles vegetable soup. I wear one of those painter's ventilator masks, sunglasses, goggles, and ear protection. I feel like I'm driving an undersea jet boat with all this stuff on and all the debis floating around me.
I've had the BX almost 7 years now and when I brushhog I have to wipe debris off the face of the screen in front of the battery every 5 minutes to prevent engine overheating. In only 5 min., the entire face of that screen is covered solid. I also have to stop every hour, open the hood, pull the inner screen, clean it, and take the long narrow nozzle on the shop vac. and vaccuum the entire face of the radiator. The entire face is completely plugged after an hour.
As I was cleaning the radiator today, I realized that the radiatior fan pulls a draft along the floorboard into that exterior screen. The floorboard is usually covered with debris from the brushhogging and I had never tried cleaning the floorboard along with the rest of the stuff, so I took a whisk broom and cleaned everything off. Voila, I was actually able to extend the period to two hours between stops to vaccuum off the radiator face!!
So, for those of you whom I know experience this same problem, keeping the floorboard brushed completely clean appears to slow down the flow of debris through the two screens on the way to clogging the radiator fins!!
   / Tip on Preventing BX Overheating #2
Also a good cleaning once in a while with dish washing liquid and water will help to keep the fins clean of any grease and other debris that will inhibit air flow thru the radiator. A clean engine is a happy engine. Also makes it easier to spot problems prior to them becoming major headaches...
   / Tip on Preventing BX Overheating #3
"I wear one of those painter's ventilator masks, sunglasses, goggles, and ear protection. I feel like I'm driving an undersea jet boat with all this stuff on and all the debis floating around me."
The imagery is fantastic! ;)
I've been known to pull up next to the shop, and give some blasts with a compressed air blowgun, including the floorboard.
Anything to get rid of the little fuzzies that clog up the fins and screens is a good thing!
   / Tip on Preventing BX Overheating #4
It'd probably be a good idea to knock the dust out of the engine air filter and housing periodically as well if you are operating in those conditions.
You're right. Thanks.
New/Unused MX-CRT23 Stand on Mini Track Loader (A57453)
New/Unused...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
Pallet of Miscellaneous Firefighter Equipment (A56860)
Pallet of...
2022 Kubota SVL 75-2 Skid Steer (A57453)
2022 Kubota SVL...
New/Unused 110V Diesel Pump with 50ft Hose (A57454)
New/Unused 110V...
