Forks Tip ends on homemade forks
   / Tip ends on homemade forks #1
Arky217
Hartford, AR
Kubota L4200
I'm making a set of chain on bucket forks for my pin on bucket for use mainly on brush, slabs, etc.
I'm using 2"x2"x1/4" sq. tubing and will be putting about a 30 degree angle on the points.
Trying to decide whether to put the slope of the angle up or down. I've seen them both ways.
Which way would you orientate the slope of the tips and why ?
Thanks,
Arky
   / Tip ends on homemade forks #2
I like them angled up so they will tend to ride the surface (instead of digging in) while I am sliding them under an object. Mine are only 1" tall. You could also make them reversible or compromise with a double taper.
   / Tip ends on homemade forks #3
My first inclination would be upwards so as to not catch the bottom of a pallet etc. but since those tubes are pretty thick compared to solid forks, maybe the double taper that Brad just mentioned would be best, so you're not spearing the ground as easily.
JB.
Ammco Brake Machine (A55758)
Ammco Brake...
2013 HERCULES ALUMINUM KILL TRAILER (A55745)
2013 HERCULES...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2016 R and R Products 331 LP Reel Mower (A55851)
2016 R and R...
