tiny tach
   / tiny tach #1
murphdasurf
Cumberland, RI
BX23
Does anyone have this installed on the machines? I don't think the BX23 has a tach. Is that correct? From what I can see it also keeps the hours count. Any ideas on this item?
   / tiny tach #4
I installed one on my BX2200 last spring. It was easy to install and I use it all of the time.
John
   / tiny tach #5
The TinyTach works great and really helps to set the rpm until you get used to the sounds and feel of the machine. I have had one for a year and even though I think I know I am up to speed the tach helps to confirm it.
Mine is mounted on the "shelf" where my cab meets the dash on my 2200
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
7022 (A50322)
7022 (A50322)
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
