Timing
   / Timing #1
doodlesone
I'm looking for the timing proceedure and specs for a JD 3 cyl. Model 510 farm tractor. I'm replacing the defective RoosaMaster distributor pump with a different one. I'm also looking for fuel additive suggestions. I believe the new fuels do not have the lubricating abilities and probably caused the failure of the original pump. Thanks in advance for the help. Serge
   / Timing #2
Can't help ya with the greenmachine timing procedure.. however.. as an addative.. i like the white bottle Power service addative.
soundguy
   / Timing
Thanks for your fuel additive recomendation. Some folks are using ATF. but not so sure if that is a good thing. Best regards SJ
   / Timing #4
Over the years I'm sure lots of ATF has been consumed by deisel engines....
soundguy
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
JOHN DEERE 17P LOT NUMBER 241 (A53084)
JOHN DEERE 17P LOT...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
