Timing off?
   / Timing off? #1
FairportCub
I have an CC1862 with a Kohler motor. Yesterday when I tried to start it, it would backfire severely when it would try to start. It sounded like a 12 gage going off. Is this a timing problem? How do I adjust it?
   / Timing off? #2
I don't believe there is a timing adjustment on the Kohler Magnum. It uses an ignition module mounted next to the flywheel, it's fixed. You might be losing spark intermittently and when it fires it's igniting that unburned fuel or maybe lost spark on one side.
I have a couple of cheap Harbor freight spark indicators that work great for these kind of problems. Hook em up inline with the spark plug, tells you immediately if it's a spark problem.
This module has a ground through the ignition switch, it grounds to kill spark.
The control for that is entering the same location as the plug wire through the sheet metal on the engine case.
I've replaced two of those module in 20 years, hope it's something simpler like a carb issue!
Curt
   / Timing off?
It's a Kohler Cammander. Does that make a difference?
Thanks for the fast reply!
   / Timing off?
Wow! Thanks alot. That manual has it all.
It is the original engine. 18HP Kohler Commander.
   / Timing off? #6
If the flywheel key sheared partially or is deformed, you'd have an ignition timing issue. Hopefully it's just a fouled plug.
Front Axle and Engine (A51692)
Front Axle and...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
3/16Th Plate Steel (A52377)
3/16Th Plate Steel...
2014 FORD F-350 (A53422)
2014 FORD F-350...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
